Piston Stroke Tolerance?
Old Aug 23, 2009 | 08:59 PM
AC's Avatar
AC
Car: Used to drive a camaro
This one is for you die hards and engine builders. I'm using a 3.75 stroke / 5.7" rod combo to make up my 383. What's the piston stroke tolerance measuring from the deck face to the piston at TDC ?? I've heard .001" all the way up to .005"
Old Aug 23, 2009 | 09:55 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Piston Stroke Tolerance?
do you want a guess as to how far the piston will be in the hole at TDC?
highly dependent on the block and the tolerance stack up from the crank, rods, piston
do you want the tolerance stack up as in how much each piston can vary in height at tdc?
again highly dependent on the companies could be as little as .0005 to as much as .010
depending on the company you could call and ask about their tolerancing practices
however don't count on them telling you.... would be better off assembling and measuring yourself
Old Aug 24, 2009 | 05:24 AM
AC's Avatar
AC
I figured it would be the tolerance stack up dictating this height. What I'm seeing is a TDC height variance of around .003", say between #2 and #8 and a little less between #4 and #6. I haven't indicated the drivers side yet.
Old Aug 24, 2009 | 07:03 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
That probably means your deck is absolutely, perfectly flat.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
dusterbd
Sep 29, 2015 08:40 AM
