82 CROSS-FIRE
82 CROSS-FIRE
CAR IN STORAGE 5 YEARS GAS NOT REAL BAD BUT DRAINED GAS AND PUT NEW GAS FOR START? STILL HARD START, HAVE POUR GAS IN , WILL RUN IF YOU KEEP PUMPING PETAL, WILL NOT ILDLE OR RUN AT STEADY SPEED CAN ANYONE HELP?
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: 82 CROSS-FIRE
Any trouble codes from the ECM? Not too familiar with the cross fire motors but I know they're finicky. First off give it a complete tune up. If that doesn't help check for vacuum leaks. Then look at fuel pressure, timing, etc
Good luck
Alex
Good luck
Alex
Transmission: 4L80E/4L80E
Replace the fuel filter if you haven't already. Run some gas cleaner through the system. You very likely have gummed-up injectors.
