Need help choosing right comp cam.
Old Aug 24, 2009 | 01:22 PM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
I am replacing the camshaft in my 305 carb motor. I have so far put on headers/intake manifold 3701. I have the stock 416 heads and was wondering what kind of performance camshaft i could get that would put me around the 300-400$ range. Edelbrock suggest the 3702 but from what i heard it suks.
My haynes repair manual says my model car has a lobe lift of intake: .238 in, exhuast: .260 in.
Im looking for a camshaft under 200$ since i will have to purchase pushrods/springs/timing chain. I am not the mechanic in my family but my father says the roller rockers sometimes needa be replaced is that true??? Or can i get away with not replacing them?
If anyone can suggest a performance camshaft on summit since its easy to match the springs/pushrods on that site since i dont got much time of research since school starts tommorrow for me. Any help will be very well appreciated.
I have heard about lt1 cams but i dont know what kind of pushrods/springs i would need and i want to make this kind of easy. Along with i dont want to buy a used cam. The lower the price the better.
Old Aug 24, 2009 | 06:54 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Need help choosing right comp cam.
You can re-use your rockers and probably the pushrods too. Buy some new springs and timing gear set.
Take a look at this Cam set..
http://www.summitracing.com/parts/LUN-60101LK/
Here's some inexpensive upgrade Springs.
http://www.summitracing.com/parts/SUM-174000/
Here's some inexpensive upgrade rockers.
http://www.summitracing.com/parts/SUM-141506/
no green
Jan 9, 2016 09:22 PM
bjpotter
Oct 4, 2015 07:48 PM
