90 firebird wont start.
Old Aug 24, 2009 | 04:14 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
ok so i had it running for a little bit on some old gas to try to get rid of the bad gas so i could put some fresh gas in it. it ran out of gas n so i put fresh gas in it. now it starts for 5 second then dies but if i pump the accelerator i can get it to stay on for like 30 seconds but it still dies. i think its the fuel filter is clogged up. i hav a new one but where SPECIFIALLY is it on the car. N is that wat yall think it is?
Old Aug 24, 2009 | 06:41 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: 90 firebird wont start.
The fuel filter on a '90 fuel injected car (TBI included) is located in the rear of the car, near the fuel tank. it's mounted transversely (parallel to the rear axle, and perpendicular to the drive shaft). Remember you need to relieve the fuel pressure in the fuel system before you perform this swap.
Are you sure you put enough "fresh gas" in and the "old gas" isn't the culprit, because after all that is what you were trying to flush the system with.
Old Aug 24, 2009 | 08:18 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
I put in ten gallons of new gas with some carb/injector cleaner. i tried to start it for like an hour so all the old gas should hav been flushed out by the new stuff right?
Old Aug 24, 2009 | 09:36 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
oh n wen i get it started i wanna make it as loud as possible without failing emissions testing. i was looking at getting a magnaflow system but i seen some firebirds that have that n sound the same n some that sound like a hot rod. How do i get it to sound like that?
Old Aug 24, 2009 | 11:26 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Well you need to understand that you need to burn the fuel before it will be gone.
You can sit there for hours trying to start your car and your battery or maybe even your starter will go before you will ever deplete your fuel supply.
Old Aug 25, 2009 | 02:06 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
i did. it was running and i let it run out of gas. but now that the new gas is in it it wont start.
theshackle
Mar 5, 2017 06:37 PM
Glowsock
Aug 31, 2015 09:01 PM
WIzmo
Aug 30, 2015 02:30 PM
destroyerwes
Aug 26, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
