external coil to traditional HEI swap?
Old Aug 29, 2009 | 11:32 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
i have an 87 LG4 based car and my freind gave me an accell super coil and cap and rotor from a 1985 tpi car he just sold, the coil is rated around 50000volts so i know it has to be a little stronger then my stock one. Would there be any benefit to switching to this? i think i would need the whole distributor. I would actually like to know if this is possible and does it hook up with the old wiring harness and everything, would this be more trouble then the results would be worth? thanks in advance... oh yeah i did a search for the topic and netted nothing
Old Sep 8, 2009 | 10:36 AM
Re: external coil to traditional HEI swap?
bump
Old Sep 8, 2009 | 10:47 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
ya i think you do need the whole distributor because the cap wont bolt up to the dizzy rite? if it does then your golden. you might need a insulator and button resistor (located under the coil in the cap).
Old Sep 8, 2009 | 07:33 PM
Towman84Z's Avatar
depends on the color of the wires from the coil.IIRC there is one with yellow and white wires and another with red and white wires
Old Sep 9, 2009 | 09:31 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Don't waste ur time, The remote coil setup is better. u can pick up a decent coil for under 50 bucks for it. With the older unit u would need the whole dizzy and u would need to modify the harness which is more pain then its worth. beside stock the coils still produce good voltage, sometimes well over 40000 volts. Accel has cap, rotor, coil and modules for ur current dizzy u should be able to get all for under 100 and have a nice ignition upgrade. Although if ur stock or pretty close to stock then ignition upgrades like that won't do anything for u maybe increase fuel mileage a bit but thats all.
Old Sep 9, 2009 | 09:48 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
The stock ignition has more than enough juice if it's in good condition. All you need are enough volts to jump a tiny .035" gap under 10 atmospheres of pressure. This does not require 50,000 volts, or even 30,000 volts.
I mean you might see an advantage if you are running forced induction, but you should really be shortening your gap in that situation.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
L98GTA87
Aug 25, 2015 02:23 PM
midias
Aug 15, 2015 05:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
