alignment pins in head and block ?
Old Aug 30, 2009 | 07:35 AM
wannaz's Avatar
Car: 90 iroc z
Engine: 350 needs work
Transmission: 700r4 needs work
I recently purchased a set of 083 heads from a member on here. The problem is the pins for alignment on hte block are also in the heads. My guess is the pins should be in the block.Could anyone tel me how to get these out of the heads so i can install my heads. I tried to pull them out with pliers but they will not move.
Old Aug 31, 2009 | 02:50 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: alignment pins in head and block ?
If you can't do it with vise grips, you'll have to take the heads to any automotive machine shop
Jake_92RS
Jan 28, 2020 10:37 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
lakeffect2
Aug 23, 2015 08:44 AM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
