Oil Capacity???
Old Aug 30, 2009 | 10:35 AM
vorteciroc's Avatar
Top Answer: 1
Oil Capacity???
How many of you are adding oil with an engine oil cooler vs. running stock capacity?
Old Aug 30, 2009 | 02:55 PM
vorteciroc's Avatar
Top Answer: 1
Re: Oil Capacity???
anyone using an aftermarket oil engine oil cooler?
Old Aug 30, 2009 | 04:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Oil Capacity???
you dont need to add extra oil.
the cooler will drain back to the pan when the engine is off, no need to remove it.
Im running an oil cooler, but also a 6qt pan, so i have an extra qt to play with.
Old Aug 30, 2009 | 04:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil Capacity???
You're NOT thinkin' with your dipstick Jimmy!
Old Aug 30, 2009 | 09:32 PM
vorteciroc's Avatar
Top Answer: 1
Re: Oil Capacity???
Interesting... Thank you :-)
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
