no feul pressure
Old Aug 31, 2009 | 04:19 PM
dirtybrd88's Avatar
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
no feul pressure
ok i got the power back to the feul pump but now i got no feul pressure at rail wat could be my culprit NEW feul pump
Old Sep 1, 2009 | 12:12 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: no feul pressure
oil sensor, are you getting prime? i think it could be a wire prob. man that be nice to help in person. but cant.
Old Sep 3, 2009 | 12:18 AM
nzo's Avatar
nzo
It does sound like oil pressure sensor or wire. What kind of PSI are you getting when it cranks? I may be mistaken, but I think 30 is the magic number. You may want to put a multi/ohm meter to the sensor wire. As a follow up for me- I still have not fixed fuel pump on the '89, but I think I will be installing an access panel. I have found a well executed design of such a thing. I can email you a link if interested. Good Luck.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
