EGR/Coolent sending unit
Old Sep 5, 2009 | 02:11 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Transmission: 700 R4
On a TPI, I was wondering what the sensor in the egr valve is called and where can I get one? Also I was wondering what the coolent sensor in the head is called, it is in the drivers side head.
Old Sep 5, 2009 | 02:23 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: EGR/Coolent sending unit
the driver side head is the dash coolant sensor. the coolant sensor in front of the block is for the computer. the coolant sensor on the passenger side block is the fan coolant switch. and theres EGR temp switch sensor behind the distributor. theres a EGR solenoid that allows vacuum to the egr on the passenger side by the distributor. i think thats all, could be wrong
Old Sep 7, 2009 | 06:05 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Looking for the coolent temp sensor in the driver side head and could not find it on Autozones website. I do not know what it looks like since mine was broken off when I got the engine. Could someone do me a favor and post a picture?
Old Sep 7, 2009 | 10:43 PM
www.rockauto.com
im assuming you have 5.0 tpi 88 trans am.
"coolant sender" 9 bucks
as for the egr sensor. is it located behind the distributor?
Attached Thumbnails EGR/Coolent sending unit-coll.jpg
Old Sep 7, 2009 | 11:09 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Have 89 350 TPI, Thanks for the picture lots of help. I took care of the EGR sensor its in the egr valve and its called egr temp
tattmann
Sep 27, 2015 05:20 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
wstephan96
Sep 25, 2015 04:28 PM
6998poncho
Sep 25, 2015 02:56 PM
lanceflame44
Sep 25, 2015 12:28 PM
