87 firebird hatch problem
Old Sep 5, 2009 | 05:59 PM
Thecasemon's Avatar
Car: 1987 firebird
Engine: 305 4barrel
I recently bought an 87 firebird. The hatch will not open with the key i have. And i do not have an electric switch. Thus resulting in the inability to take off the rear panel to fix anything that may be broke behind if. If anyone has any advice or experience with this, i'm all ears. Thanks
Old Sep 5, 2009 | 11:25 PM
topfile's Avatar
Re: 87 firebird hatch problem
I'd drive it to a Locksmith and let him open it.
Just to be clear you don't have a Solenoid Hatch release but a Manual Cable Hatch release that's not working correct.
Old Sep 6, 2009 | 12:03 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
drill the lock. and replace. thats what id do. skip the lock smith use that money to get a new lock. or crawl to the back from inside the car, take the plastic screws out the access the lock and pry the mechanism apart, youll see what im talking about.
Old Sep 6, 2009 | 02:40 PM
Thecasemon's Avatar
Car: 1987 firebird
Engine: 305 4barrel
well i cant get the plastic off the back without breaking it
Old Sep 22, 2009 | 03:21 PM
spud522's Avatar
Car: 1990 Firebird
Engine: SBC 383c.i.
You can pull out the small light on the back trunk plastic from the inside. If you look through the opening with a flash light, slightly to the right you will see a round indentation with a slot in it. You can insert a straight slot screwdriver in the slot and turn the latch and it should open. That is how i opened mine when i had the same problem. Hope that helps!
Street Lethal
Apr 30, 2019 12:14 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
Randomtask2
Aug 13, 2015 01:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
