valve adjusting !!!
Old Sep 5, 2009 | 07:45 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
valve adjusting !!!
ok so im adjusting my valves on my 88 lo3 and im reading the instructions on how to do it from the haynes manual , and im following the directios but when working on intake valves 1-5-7 i tighten them until i reach zero valve lash the the 3/4 turn and still its the rocker arm wiggles just a little bit yet the pushrod is tight as heck ! ok , so then i crank the crankshaft 360 degrees to do the exhaust valves and i only have to adjust 1-3 " btw im only doing my 1-3-5-7 because someone messed with them " then i check all my othe valves that i had previously adjusted and they are loose , i can spin the pushrod , and when i try to adjust number 3 on the intake it only takes 2 turns to reach zero valve lash whereas it me 7 turns to reach zero valve lash on all the other valves , wtf is up with this ??? any suggestions ?
Old Sep 5, 2009 | 08:35 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: valve adjusting !!!
the manuals all talk about "spinning" pushrods... dont do it that is more of a art than anything
what they mean is to remove all slack IE there is no play vertically in the pushrod between rocker and valve do not try and tighten them untill you cant turn the pushrod...
they mean NO SLACK ONLY then go 1/2-3/4 turn more
Old Sep 5, 2009 | 08:47 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
the lifters are bleeding down on the valves that you already adjusted. it's ok.
Old Sep 5, 2009 | 08:50 PM
so is it ok if the rocker arm wiggles a little bit after you have adjusted the valve ? and is it ok if you can still spin the pushrod?
Old Sep 5, 2009 | 08:55 PM
Car: 91 RS
Engine: 350 vortec
yes you should be able to spin the push rod when the lifter is on the heel of the cam its lowest point...
i only use the method you are using as an initial set up on the stand once the engine is in and running i re-adjust with the engine running
Old Sep 5, 2009 | 08:57 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
yep. i have done hundreds of hydraulic cam motors. they will pump back up when primed or started.
Old Sep 5, 2009 | 09:02 PM
ok so from being @ tdc on cylinder #1 on the copression stroke i adjust the valves the manual said to adjust , then i rotated my crank shaft 360 * and im supposed to be @ tdc on cylinder 6 then i could adjust intake on that cylinder , but its copressed as hell and i really cant adjust it , is this supposed to happen ? and btw if i ran my car without the valve covers it would get messy .. real messy
Old Sep 5, 2009 | 09:15 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
cylinder 1 and 6 are companion cylinders. they should both be at tdc at the same time.
Old Sep 5, 2009 | 09:26 PM
the book says , position cylinder one @ tdc on the copression stroke , adjust 1-2-5-7 intake valves and 1-3-4-8 exhaust valves . Then rotate the crank shaft 360* and this should put cylinder number 6 @ tdc on the copression stroke . Then adjust intake valves 3-4-6-8 and adjust exhaust valves 2-6-3-7 NOTE: i am only doing the drivers side of the engine since this was the only side that was messed with . i do all this and when i rotate the crankshaft all the previous valves i had adjust come loose and i cant adjust 3 intake valve because its compressed and it takes very little to tighten it and it dosent take as much as it took all the other valves . what a m i doing wrong?
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
