what valve springs do i use?
Old Sep 8, 2009 | 07:42 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
I have a set of World Sportman II iron heads that need new springs.I need to know what size to get for a stock cam with roller lifters and 1.6 roller rockers and also what length push rods. I appreciate any help thanks.
Old Sep 8, 2009 | 10:08 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: what valve springs do i use?
You probably dont need crazy springs at all. Just get something good to .550 lift and call it a day.
Old Sep 9, 2009 | 08:32 AM
Damon's Avatar
To stay cost-effective it's probably a good idea to get springs that are the same diameter as your existing retainers so you don't have to buy a new set. For (stock size) 1.25" retainers a set of Comp 981s will do fine with that combo of parts. For larger 1.45" retainers a set of Comp 986s would work fine, with 987s being acceptable as well, if a bit of overkill for a stock roller cam. If they're the big-boy 1.55" retainers you won't find what you need and you'll have to get a smaller set of retainers to work with appropriate springs.
Old Sep 9, 2009 | 09:30 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
What's the maximum RPM and how much lift at the valve will your 1.6 rocker arms get you?
As for pushrods, who knows, you'll need to measure that.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
