help! What the hell is this!
Old Sep 12, 2009 | 03:04 PM
73duster's Avatar
I have oil in my throttle body. It's also inside the plenum.I have no idea where it's coming from. It's a first fuel injection set up, but it's really no different than a stock intake theoretically. I can't imagine it coming up through the runners and out in reverse flow of intake air. WTF.[ATTACH]help! What the hell is this!-throttle-body-002.jpg[/ATTACH]
Old Sep 12, 2009 | 03:24 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: help! What the hell is this!
Could be from the PCV valve?
Old Sep 12, 2009 | 05:34 PM
Thing7's Avatar
Car: 1991 Comaro Rs
Engine: 3.1L V6
Transmission: Auto 700R4
Axle/Gears: 10 Bold Stock
I'm with DartByU That is common in high performance motors
Old Sep 12, 2009 | 06:36 PM
73duster's Avatar
so i should'nt be worried?
Old Sep 12, 2009 | 06:39 PM
Damon's Avatar
Is there a breather hose (not the one with the PCV, the other one that supplies fresh air into the engine) connected to the air filter plumbing between the air cleaner housing and TB? If so, a clogged PCV can cause the blow-by gasses to flow out through that hose instead of into the motor like it's supposed to, taking oil vapors with it.
Old Sep 12, 2009 | 06:54 PM
73duster's Avatar
no hose on the breather, it is a stand alone breather. I think it is the pcv. Do i replace it?
Old Sep 12, 2009 | 07:11 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Pull it out of the valve cover and shake it. If it rattles it is ok, if it doesn't, it's junk. No more than 5$ at your local parts store...
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
