91 Camaro RS starting/stalling
Old Sep 13, 2009 | 01:25 AM
bdm91camaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 5 Spd
I have a 91 Camaro RS with the 305 TBI. For some reason when I initially go to start it, it will run for about 2-4 seconds and then die. It does this for about 4-10 times before it will actually run. Then it could run great for hours, or more often than not, it will die out again randomly while going down the road . [Note when it stalls or dies there is no sputtering or spitting and all electrical stays on. It is just the motor stopping.] Any help would be greatly appreciated.
Old Sep 13, 2009 | 07:52 AM
Thing7's Avatar
Car: 1991 Comaro Rs
Engine: 3.1L V6
Transmission: Auto 700R4
Axle/Gears: 10 Bold Stock
Re: 91 Camaro RS starting/stalling
I'm having a problem like this but mine starts fine. The first thing that comes to mind is fuel delivery Second is a weak ignition system third is cloged exhaust
Old Jul 1, 2010 | 01:22 PM
25th Ann Camaro's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 ci
I'm having the same problem with my 1992, any help would be greatly appreciated.
Old Jul 2, 2010 | 12:17 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Have you checked Ignition timing, or Ignition control module (the thermal grease under module can dry out)? Hows the fuel filter and fuel pump? Are plug wires and plugs in good/ optimal condition?
Old Jul 2, 2010 | 10:33 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Check the fuel pressure, could be a original fuel filter, or a pump going bad. What happened to mine was the little rubber connector hose between the pump and the metal line rotted a hole and couldn't pump enough to keep it running.(was loosing pressure). So I say check fuel pressure if its low, replace the filter first and check again, if problem persists, your gonna have to drop the tank:/
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
