Just wondering what intake manifolds some of you guys have used on BBC swaps to clear a stock hood? I'm using a flat steel RS hood on my '83 right now.
I don't really want to use the cast iron intake my 454 came with, because its a big heavy boat anchor, and I don't have a spreadbore carb to use on it anyway - only my 4779 Holley. I do have my L88 air cleaner as well, with its nice 2" drop, which is a big help.
The 454 is going to be run just as-is for awhile (Mk IV block, flat top pistons, 781 large oval heads, stock cam/valvetrain, 2226 headers and my MSD stuff from my 350).
Just wondering what other people have successfully fit under a factory hood with a BBC? Edelbrock's Torker-II would fit, as its listed to fit under a stock Corvette hood, but its a POS in the SBC version - is the same true for the BBC version? I've done a search, didn't find anything I was looking for.
Anyone?
yes, Edelbrock's Torker-II fits under your hood, i have bbc 502 and Edelbrock's Torker-II and it fits
Irockz
close
- Join DateMar 2005
- LocationSpringfield,Mo
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car87 Berlinetta,work in progress
- Engine468 BB,still in the build process
- TransmissionTH350,3500 stall
- Axle/Gears9" Ford,learning how to live under
- Liked:0 Times in 0 Posts
They aren't terrible,they aren't great.I can't promise you,because mine had a cowl hood.But I remember thinking that Performer would likely fit under a stock hood with a BB,I had a Weiand Stealth on mine,and without the spacer,It barely stuck up over where the stock hood would have set.
