350-305 tpi what to do
Old Sep 14, 2009 | 03:41 AM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
ok i have a 86 i roc with a 305 tpi i also have a 350 out of a 95 1/2 ton chevy truck wanting some opions on what to do i want to keep the tpi setup but with the 350 having new style heads and the 305 having old style which the tpi is on will it fit the 350? or could i put the 305 heads on the 350 block what would be the best out come for a mild street car what kind of tuning and so on
Old Sep 14, 2009 | 04:38 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350-305 tpi what to do
This may surprise you, but those particular 305 heads will outperform those particular 350 heads. You'll need to run premiom unleaded if you do that swap, but that's your better option with what you have.
Old Sep 15, 2009 | 01:41 AM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
