Engine whistling when revved
Old Sep 14, 2009 | 07:12 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Today I went to start the car my battery was toast, charged it, got it started, ran for about 4-5 mins. When i was standing in front of the engine revving it via the TB, I noticed a whistling noise. My engine has always sounded like this, but i didnt think anything of it until today. im thinking now it may be a vacuum leak. The only way i can describe the sound, is that it sounds like a supercharger sound/whining sound. What do you guys think. I watched some vids on youtube, and it seems like there is some whistling from other peooples engines, but mine gets really loud especially at higher RPMS. I have a vid that i took of it, that ill post on youtube, but i need to convert it first.
Also i have been fighting with a code 33/34 for a while now. I have tried everything, but the CEL still comes on. Today when i got the car started, the CEL didnt come on? The only thing i can think of is that when i unplug the battery to clear the codes i take off the pos instead of the neg. would that make a difference?
Old Sep 14, 2009 | 06:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Engine whistling when revved
A bit of a whistle is normal. My LT1 does it, as well as my carb'd engines. Just the sound of air being pulled through the throttle blades at a high speed is all.
Old Sep 14, 2009 | 11:51 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
^Same here.
Old Sep 15, 2009 | 06:49 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
thanks guys, didnt think there was anything wrong!
Old Sep 15, 2009 | 07:26 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
When I put a gator-back belt on my Jeep it started to make a small whistling noise.
theshackle
Sep 17, 2020 08:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
