TPI Gasket Faces
Old Sep 16, 2009 | 11:27 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
TPI Gasket Faces
I had my plenum, runners, and intake manifold all bead blasted to make them look new before installing them on the new engine. The machine shop bead blasted all of the gasket faces with sand, so they are not "shiny" anymore and instead have a tiny grain to them. With this impact the seal? Should I polish all gasket faces before installing?
Also, can I coat with anything to keep the aluminum looking new?
Thanks!
Josh
Old Sep 16, 2009 | 02:36 PM
Pocket's Avatar
Car: 91 Trans Am
Re: TPI Gasket Faces
Check the Appearance & Detailing forum for keeping the alum shiny
Bead blasting wont pit the alum enough to compromise a seal. Install it without worry
Old Sep 16, 2009 | 04:07 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I hope they actually bead blasted your aluminum and not sand blasted it.
Blasting aluminum embeds the media in the aluminum. You don't want sand falling into your engine.
Glass bead and whatnot is not so much a problem.
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
Sanjay
Aug 12, 2015 03:41 PM
