Tried searching...to no avail. Help with fuel leak.
Old Sep 19, 2009 | 04:49 PM
5.SLOW's Avatar
Car: 1991 Z28
Transmission: 700-R4
Axle/Gears: 10 bolt Disc/Posi
Just picked up an 87 GTA with a 350tpi
I have replaced the proverbial "****-list" of stuff....MAF, MAF power and burnoff realys, plugs, wires, cap, rotor, coil, ign module, fuel pump, fuel filter...etc. etc.
My problem started with the evap canister loading up with fuel. Between that and the bad MAf sensor harness (caught inbetween the fan/radiator) the car was running so rich it wouldnt idle at all.
after repairing the harness and a new MAF sensor and evap canister.....the car runs great.
I am now starting to notice the evap canister loading up with fuel again. I have no check engine light, and it doesnt seem to be running rich....yet.
My question is this.....what would cause the evap canister to be loading up with fuel? Fuel pressure checks out ok...FPR passed the "no fuel in the vacuum line" test and all of my injectors ohm out as they should.
Old Sep 22, 2009 | 07:46 AM
5.SLOW's Avatar
Car: 1991 Z28
Re: Tried searching...to no avail. Help with fuel leak.
anybody? bueller?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
