zz4 build info
Old Sep 21, 2009 | 08:08 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
zz4 build info
hey all starting to make a list for my spring time build and need some input,
i currently have a zz4 350 and would like to change the intake,cam and heads and this is what i was looking at
afr 195 heads (65-75cc??)
victor jr intake
1.6 rr's
my biggest problem is choosing a cam. i am totally lost any info? i was looking into comp cams or isky. i would like it to have a nice chop to it
thanks
Old Sep 21, 2009 | 08:22 AM
Shadow Z's Avatar
Car: Lots of 'em
Re: zz4 build info
I know it's not what you want to hear, but your best bet is to stay away from the cams that will give you the "chop" to the idle, just because you like the sound.
I can 100% guarantee you, if your car will be used as a frequent, or daily driver, you will hate it.
High duration or better known as "choppy" cams give engines the worst throttle response I have ever seen in my life. Again, if this car is used as a frequent driver, you will definitely be a lot happier with a low duration cam, something along the lines of a 230/230. You'll have very good amounts of low end torque, and an incredible powerband, depending on your pistons, you'll have usable power from 1,000 to 6,500+ RPM. Plus some of the snappiest throttle response around.
The previous owner of my Iroc put in one of them ridiculous choppy cams, just another money pit for me when I get the engine rebuilt..
But anyway, to get back on topic! I don't know much about AFR heads, but if it's a 75-76cc chamber aluminum head, chances are it'll perform great. Plus, almost all of Edelbrock's intakes are awesome, can't go wrong with the Victor JR. Flow like there's no tomorrow without emptying your wallet.
Old Sep 21, 2009 | 09:23 AM
F-Body Demon's Avatar
Re: zz4 build info
Call comp cams, they will grind you a custom camshaft for the same price as just ordering one from summit. Not to mention they should know much more about picking the perfect cam for you than most of us.
Old Sep 21, 2009 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Nobody can possibly make a cam recommendation unless they know what you're going to do with the engine/vehicle. Pure race? Daily driver? Street/strip? Transmission? Gears? Tires?
Old Sep 23, 2009 | 10:34 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Re: zz4 build info
gonna be street/strip, th400,3:73's not sure on tires right now. was looking at comp xr294hr
Old Sep 23, 2009 | 10:56 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: zz4 build info
Even with a serious cam, it's still just a 350, so go with the AFR 180cc heads. The stock bottom end of that engine won't take many trips past about 6000 rpm, so choose your cam accordingly. If you want more, then spend your money on forged pistons, ARP rod bolts, and a good re-balancing.
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Jorlain
Oct 8, 2015 01:57 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Thornburg
Sep 12, 2015 10:11 AM
JamesC
Northern Great Plains and Rocky Mountain
Sep 10, 2015 07:41 AM
