excessive rich?????
Old Sep 21, 2009 | 08:54 AM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Axle/Gears: 10bolt/4:10
excessive rich?????
i recently swapped my 88 2.8 rs 5 speed to 5litre tbi auto. i got it running but it is running very rich!!!! i hooked up the scanner and watched data, i had no o2 reading.... it was stuck at 438mv indic lean. chnged sens. same thng. found out becuz i used ta eng harness that the o2 wire ran out the other side, or so i thnk cuz i ran my own wires and i got o2 data.. it does have a code 45 rich exh... now another thng is the car i got the dash harness out of had vats and the key and even the colomn were gone. so to get it to crank i bypassed the starter enable relay and then i ran into the prob of vats killing the inj so i used an ecm from an 89 s10 vin z wich u would thnk shld work cuz i also did a v8 s10 swap and kept it efi with 4.3 ecm and have been driving the truck for yrs with no problems, not saying its compl rite but it does wrk fine and never sets eng lite. all data on the camaro reads good such as map tps cts, and o2 is a little wacky i thnk cuz of how rich it is??? i didnt check fuel psi yet and maybe reg??? idk any suggestions greatly appreciated!!! thanks
Old Sep 21, 2009 | 08:00 PM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Re: excessive rich?????
alrite!!! finally i got it!!!! did fuel psi test and found it was doubled what spec was.... checked the fuel return and she was blocked solid, cleaned line out and it runs awesome. (as good as a stock 305 tbi cld run lol)
Luigytico09
Oct 1, 2015 08:46 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
