fuel pump replacement
Old Sep 22, 2009 | 07:35 PM
cdh_3752's Avatar
Car: 92 rs heritage
Engine: 5.0 tbi
sorry if this is already posted somewhere but ive been looking for a how too or some tips on how to change the fuel pump on my 92 tbi 5.0 camaro ive looked but cant seem to find anything so any help would be greatly appreciated
Old Sep 22, 2009 | 08:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel pump replacement
Assuming you do not want to hack a hole in the trunk:
https://www.thirdgen.org/forums/tech...p-not-bad.html
Hope that helps. Think I forgot to mention removing panhard bar, but it's kinda obvious since it's in the way.
Old Sep 23, 2009 | 09:14 PM
cdh_3752's Avatar
Car: 92 rs heritage
Engine: 5.0 tbi
Thanks for the help but you've got me wondering what I'd have to do to go through the trunk seems like it would be much easier I understand I'd have to cut but where ? And would there be anything to watch out for does anyone know of a write up for this way thanks in advance for the help
Old Sep 24, 2009 | 08:37 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
The design of our sending units does not lend itself very well to a pass-through without quite a bit of modification. Since the hardlines on the sending unit go across the tank and down the front, you have to do a lot of hacking to the hatch area to make it possible. Now you can modify the sending unit, but you also have the chance of introducing leaks if you've never made flared ends before.
Dropping the tank is a pain, no question. These cars require you drop the rear end and exhaust to get enough clearance. You can get away with just dropping the passenger side of the rear, but it will make things more difficult. Definitely give yourself a day or two if you've never done it before.
Old Sep 24, 2009 | 02:12 PM
cdh_3752's Avatar
Car: 92 rs heritage
Engine: 5.0 tbi
thanks everyone for the help honestley im thinking that ill go through the hatch i understand this isnt the right way but seeing as this car has 208xxx miles and its current condition its not a huge deal to me i do plan on doing it the right way even though its wrong if that makes any sense my questions are 1. does anyone know where exactly i need to cut i want to make this as clean and small as possible 2. what would be the best way to make the cuts in the floor and the cuts in the lines 3. what would be the best way to re atatch the fuel lines 4.is there any thing i may have missed or any tips anyone who has done this may have id like to know as much as possible about what im doing before i start thanks cory
Old Sep 24, 2009 | 02:25 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Dropping the tank and doing it right is not that hard, took me 3.5 hrs and was finished, it doesn't take a day or two...
Old Sep 24, 2009 | 04:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I was being a bit generous with the time. If someone is a bit new to the task, its better to budget more time and be done early than to go over what you expected and be up the creek.
It took me about 30 min to drain the tank before I even got to crawl underneath, then had to run to the part store to get new clamps because my old ones were rusted.
But I'm still with you on this one J91; dropping the tank is will still be quicker than cutting up the trunk the right way.
The cutout method can be done, but to do it right will take more time than dropping the tank.
Old Oct 20, 2009 | 04:56 PM
cc305's Avatar
Car: '92 camaro rs
Engine: 305 tbi
i really hate to thread jack, but can someone list the tools needed to drop rear end and tank to get to the pump? i'm doing it all this saturday and tonight i'm rounding up all the tools i need. thx. and sorry for the thread jack.
Old Nov 12, 2016 | 08:35 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Here is a video on cutting. If you want to remove the whole unit, if you want to just cut and remove make sure there is no fuel in the lines and replace it with fuel hose.
Old Nov 13, 2016 | 08:19 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
I cut the hole in mine. I dont have the facilities to drop the tank. Took me about an hour or so. The hardest part was putting hose over the lines with all the hose clamps.
Old Nov 14, 2016 | 08:35 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old Nov 14, 2016 | 11:56 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Originally Posted by Bob88GTA
Lol, yeah that is NOT the way to do it!
I agree dropping the tank is probably the "right" way to do it. I cut the hole in mine and don't regret it. I know this debate has been beaten to death and some people get real defensive of their preferred method. For me it's a matter of choice but whichever way you go you will need the appropriate tools, time and plan your work. I agree that a previous poster could do in in 3 or so hours under the right circumstances. I would allow for more time. Rusted/seized bolts, differences in exhaust, available tools (and/or help) etc can all be a factor in how long it takes.
Old Oct 4, 2024 | 05:50 PM
Iroc1988ThePas's Avatar
Thanks, this thread was very helpful. I am currently deciding on the route I want to take and this helps me decide.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
