A couple general questions...
Ok I'm replacing my head gasket myself and i'm pretty much done except for a few things that i need help on. first thing is i need to know which plug on the distributor goes to which spark plug. Second, i didn't mark where all the vacuum lines go so if you could post a link for a diagram or something that would be awesome. And third, i can't figure out how the all the brackets on the passenger side of the engine go to properly mount the alternator.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The distributor cap terminal the rotor is pointing to when the engine is in the #1 firing position is the one that the #1 spark plug wire goes to. (I'm not being a wise guy, the message is it doesn't matter which terminal it is on the cap, it matters which one on the cap the rotor is pointed to.)
By the way, "#1 firing position" and "top dead center" aren't the same thing.
There are some vacuum diagrams in a thread on the FAQ forum.
Try a search on the bracket question. I know there are pics in the "father/son swap project" sticky in the Engine Swap forum, but I couldn't tell you where in that long thread to look.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
