Vacum questions
Car: 89 GTA
Engine: 406
Transmission: 700 R4
Vacum questions
Hey guys need some help. Picked up a 89 TPI L98 car without the engine in it and wondering if I can get pictures of the vacum lines. Does my car have a vacum solenoid on the coil bracket? The car has a SLP intake, I know it moves the canister to the other side of the car so what does that do to the lines? I did a search and did not come up with much.
Thanks for all the help
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
Re: Vacum questions
the soli on the bracket is for the EGR valve and the SLP kit came with longer vacume lines that go into the throttle body.
Car: 89 GTA
Engine: 406
Re: Vacum questions
Is that the location SLP used to replace it? I thought they put it next to the battery and radiator??
Did the plug design change in different years for the EGR vacumn sensor under the coil? Picked one up from the junkyard today and my harness did not plug in??
Can someone show me pictures of how the lines run for both vacumn and canister??
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
