ignition switch problem
Old Sep 26, 2009 | 08:57 PM
jdracing's Avatar
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
I may have asked already,but really need some good advice about this.
I wanna hear those flowmasters moan again.
I took my kids for a haircut and sitting in the parking lot thought i would listen to the radio.WELL..........
The first time I turned it off i cut the switch back to accessory side and it breaks.
I have no idea what has happened,but it is stuck on the acc. side and can twist the switch key,but nothing happens. It just stays on the radio side as if I would rather listen to the radio than that deep mellow tone of those v8 tailpipes just a humming that SWEET song.
Is there a part I need to buy,or is this a fix I can do without having to spend more money?
If it has to be repaired can someone walk me thru what I am going to need to do?
The switch moves to the start side,but it doesn't move the ignition mechanism with it.
I guess that is what I am trying to say?
Thanks for any help.
You can best reply to my email address below,or to this thread.
msjdracing@rtmc.net
Thank you all for helping me keep my camaro alive 4ever.
jd=jeff in N.Carolina
Old Sep 27, 2009 | 10:34 AM
50bmgshooter's Avatar
Re: ignition switch problem
sounds like the op rod popped out or the ignition switch.
check it out its located down on the coloum
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
