car has sat for a year... what needs checked/changed?
Old Sep 27, 2009 | 02:45 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my 87 gta has been severely neglected for the last year or so, and in the year before that it was barely run.
what all do i need to check/change for a 3-4 mile drive to my new house, and for me to start driving it on the weekends again? need it ready to go in the next week or two since i'm moving but i would like to get it running tip-top again once i get it there also.
Old Sep 27, 2009 | 03:12 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
Re: car has sat for a year... what needs checked/changed?
you should be alright to drive it those 4 miles to the new house.
When i bought my 87 TA, it had been sitting for 2 years. I drove the car 35 miles to get it one but once i got it there I put new plugs, gas, oil, filter, coolant and tires on it.
Im going to do a trans service and drain and fill the rear end before i start racing it at the track though.
Old Sep 27, 2009 | 04:46 PM
1meanGTA's Avatar
how long does it take for gas to "go bad?" just wondering if i should siphon it out and put fresh gas in.
Old Sep 27, 2009 | 05:02 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Dont worry about it. Just top off the gas and fluids and drive away.
Old Sep 27, 2009 | 06:09 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Not sure how long it takes for gas to go truly "bad", but running a crate engine on gas that's over a month old will often void the warranty. Just food for thought
Old Sep 27, 2009 | 08:01 PM
yamaha6611's Avatar
make sure your brakes are legit. sitting for that long the calipers could really easily be locked up or get stuck when your trying to get it to your new place. throw a bottle of injector cleaner in there, and drive to your new place.... should be fine. i just drove my trans am an hour south to my house, it barely ran and i couldnt get it to do over 40. threw a bottle of cleaner in there and boom i was doing an easy 105mph just testing it out.
customblackbird
Aug 15, 2021 10:16 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Brcharrelson
Aug 26, 2015 07:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
