1990 camaro 350 no start
Old Sep 28, 2009 | 02:19 PM
bondwes's Avatar
I have a 1990 Camaro RS with the TBI 305, and it has quit running. I have no spark and the injectors will not spray. I have battery voltage to the coil which is not in the cap.
Old Sep 28, 2009 | 03:26 PM
50bmgshooter's Avatar
Re: 1990 camaro 350 no start
check out your vats
Old Sep 28, 2009 | 03:46 PM
bondwes's Avatar
I disconnected the vats wires coming down the steering and my meter showed the same resistance as the key by itself in the on and start position. The motor will wind over but injectors will not spray and I have no spark.
Old Sep 28, 2009 | 03:57 PM
did you check your ecm and injector x2 fuses?
also if there is other things that stopped working at the same time chech the fusable links by your starter
Old Sep 28, 2009 | 04:00 PM
bondwes's Avatar
While troubleshooting, spark and injectors started working but the car quit running 2 miles down the road, and has the same issue again which discredits a bad fuse or link.
Frozer!!!
Jan 19, 2024 04:55 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Sanjay
Aug 12, 2015 03:41 PM
