crankshaft help
Old Sep 28, 2009 | 04:35 PM
schottout's Avatar
crankshaft help
trying to install my stock crank in a 350 but when ever i tighten the main caps the crank locks up and i have checked that the main caps are in the right order any help would be great thanks
Old Sep 28, 2009 | 04:53 PM
50bmgshooter's Avatar
Re: crankshaft help
are the main caps facing the right way?
are you sure you have the right bearings?
try tightening them one at a time see if you can turn the crank
Old Sep 28, 2009 | 06:31 PM
schottout's Avatar
Re: crankshaft help
there all facing the right way and im using the standard size bearings for it its a its a 3970010 block and a 3932442 crank and ive tried tightening just one cap at a time andsoone as i tighten one it locks but when i was tearing it apart the first time the crank spun freely with the old bearings in it so i dont know
Old Sep 28, 2009 | 06:37 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: crankshaft help
You may have mis-labeled oversize bearings. Did you measure them (thickness)?
Old Sep 28, 2009 | 07:35 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: crankshaft help
sometimes the fillet on the crank requires narrow bearings.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
LT1Formula
Aug 20, 2015 09:36 PM
