355 build up suggestions are welcome!
Old Oct 2, 2009 | 07:06 PM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
okay i just got an old 350 out of my local junkyard. it has some .030 over flat-top 4 reliefe valve pistons. cam is unknown as of now. i wanna use a set of 5.0 HO heads i have laying around because basically i have a new top end ie. heads rebuilt, new carb edelbrock i believe its a 600 ill have to check to make sure, and new edelbrock manifold dual plane performer. i wanna know if this will work so i can use it as a daily driver or just something that i can drive for now until i can get some better heads for the motor. the tranny i have a t5. also any other sugestions would be great. i have built a 350 before and it was really a nasty engine so im not new at this, but last time i had help from a friend with parts this time im on my own.
Old Oct 3, 2009 | 04:44 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 355 build up suggestions are welcome!
The compression might be a little high.
Old Oct 3, 2009 | 11:08 AM
ssj2link's Avatar
Engine: 5.7/5.0
will it be to high or will it be okay to drive around. im not looking to race or anything like that now because my t5 wont hold the power im sure of it. im gonna be rebuilding the t5 and making it a world class and hopefully upgrading all the internals. but for now i just wanna be able to drive the car.
Old Oct 3, 2009 | 12:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
you'll need premium unleaded and octane booster every time, even if you use a cam like this one: http://www.competitionproducts.com/p...p?number=E1129 which will help with avoiding detonation. With any cam more sensible than this one, you'll still be having some detonation. After all, you'll have compression approaching 11:1.
Old Oct 3, 2009 | 12:52 PM
ssj2link's Avatar
Engine: 5.7/5.0
so basically my best bet would be to sell off these heads or get them maybe ported?? if i were to get new heads what is a good one to look for or to go with. im on a limited budget but maybe i can get some good stuff
Old Oct 3, 2009 | 12:59 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If money is tight, just find a pair of 882 heads. If you can afford to spend $600 on a pair of heads, you have more options. Porting the heads you have isn't going to help with the compression issue.
Old Oct 3, 2009 | 01:06 PM
ssj2link's Avatar
Engine: 5.7/5.0
okay are the 882 heads a decent set of heads? there is a set on ebay off a 76 vette i can probably get for a good price
Old Oct 3, 2009 | 05:25 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
882s are the most common 76cc heads, but 993s are another plentiful choice, though half of them cam from mexico. Still, they're both 76cc heads, and that'll get you around 9.0:1 and they're both better than 624 heads. You should be able to get a pair of heads in excellent condition for well under $300. At my local Pick-N-Pull they go for $80/pr., but condition is a matter of luck. If you go this route, choose a cam like COMP's DualEnergy255H10, or COMP's PureEnergy. If you want a little more, try the DualEnergy265H10.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
Billy Decker
Sep 4, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
