cylinder heads
Old Oct 4, 2009 | 09:24 AM
BTLD_LS1's Avatar
Car: 1998 Z28
Engine: LS1 347
Axle/Gears: 3.23 currently
cylinder heads
Putting a 355 in an 86 Z28. Motor is nothing special, cast pistons, "X" rods, new steel crank, Comp 268H (218/218 .454/.454), older Performer intake with a Carter AFB Carb (not sure on CFM).
I have 3 heads choices:
Ported 882's
Stock 14022801
Stock 14102193
I believe the 14022801's have smaller valves than the others so I think I'm leaning away from those. This is just a street car, so maybe the 882's would be best....
Has anyone built a combination close to this? I'm thinking my best bet, performance wise, is to port the 14102193, any suggestions?
Old Oct 4, 2009 | 10:30 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: cylinder heads
Aren't those all open chamber heads?
My ported/milled 882's do pretty well.
I've heard that 193's can make some respectable torque though.
Old Oct 5, 2009 | 10:00 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: cylinder heads
i like the 882s myself, they work fine for me.
Old Oct 5, 2009 | 10:03 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: cylinder heads
With that cam, the 882s aren't going to show any advantage over the 193s. The 193s will give more compression.
Old Oct 5, 2009 | 10:09 AM
BTLD_LS1's Avatar
Car: 1998 Z28
Engine: LS1 347
Re: cylinder heads
What kind of compression are you guys running with the 882's? I'm thinking my compression is going to be very low (8:1-8.5:1) with them.....
Old Oct 5, 2009 | 11:17 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: cylinder heads
i got some where around 9.5 to 1...but my heads are milled and the pistons are flat top
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
