Q on 113 heads, rockers, guide plates, etc.
Old Oct 4, 2009 | 08:47 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I am installing 113 heads on my 350. The heads I pulled off are 810 heads with self guiding rockers.
The 113 heads have guide plates on them, but I see online that a 90 model vette used self guiding rockers. I am guessing these plates were added later? Or did the vette use both?
Main question, can I use both? Or do I need to pull the plates off and run my self guiding rockers?
If I need to pull the plates off, what is the torque spec for the rocker studs?
Old Oct 4, 2009 | 10:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Q on 113 heads, rockers, guide plates, etc.
All alum Vette heads (128 / 113 ) use self aligning rockers.
The "guide plates" you see on SA heads are only plates used at the factory for assembly purposes ; not true hardered plates for use with non SA rocker and pushrods
Old Oct 4, 2009 | 11:56 PM
Guest
Guest
Posts: n/a
Pick one or the other. Since you are using the self aligning rockers, remove the plates.
Old Oct 5, 2009 | 05:43 AM
Dale's Avatar
Engine: 350 S-TPI
Alright, anyone know what the torque spec is for the studs when I put them back in?
Old Mar 5, 2010 | 01:13 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
Do these heads have 3/8 studs?Gonna order some rockers today wanted to be 100%
Old Mar 5, 2010 | 02:57 PM
Dale's Avatar
Engine: 350 S-TPI
I reused the rockers that I had which were stock, which I am thinking was 3/8.
Old Mar 5, 2010 | 05:48 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
AFR calls for 55-60 ft/lbs for the rocker studs on their aluminum heads.
lt500r55
Sep 1, 2021 01:30 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
