Rate my 350 build
Old Oct 4, 2009 | 11:00 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Rate my 350 build
350 2 bolt main, 1 piece rear, block
Patriot Performance Vortec heads- flow 240 cfm at .500" lift
Comp cams XR276HR or XR282HR
Performer RPM Air Gap intake
Holly 750
Summit Stage 1 forged connecting Rods: Adv. Rating 525hp/6000 rpm
Speed-Pro Hypereutectic Pistons
Comp cams HE Roller Lifters
1.6 Proform self aligning roller rockers
Comp cams HE pushrods
ARP bolts all around
I think this should be a decent setup that I could spin to 6k rpms. Thoughts/opions/comments?
Old Oct 5, 2009 | 10:01 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Rate my 350 build
that'll be fine. use the 276 cam.
Old Oct 5, 2009 | 06:05 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
do you think this set up will good enough for at least 400hp at the fly?
Old Oct 6, 2009 | 10:51 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
depends on your exhaust system, which you didn't give one word about, but get headers and good exhaust, then you'll be over 400 crankshaft HP easily.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Aug 24, 2015 09:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
tmellott89
Aug 16, 2015 02:58 PM
