Using Stock 1979 Heads
Old Oct 5, 2009 | 06:02 PM
wesrams1's Avatar
Car: 1992 Camaro RS
Engine: 350 .060 over
Transmission: stock
Axle/Gears: stock for now
Well I am about halfway done with my 350 build and I am realizing i dont have the money to buy new heads. My engine is a 1979 350 and im gonna just use my stock heads for a few months until i can save up to buy some decent heads. I dont want to have any machine work done cause i dont have the money. What can i do to get these heads in decent condition to run for a few months? Can I just bolt them on as is?
Old Oct 5, 2009 | 07:06 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Using Stock 1979 Heads
Originally Posted by wesrams1
...What can i do to get these heads in decent condition to run for a few months? Can I just bolt them on as is?
You can check into having them milled/resurfaced, most shops will do it for $20 per head. You can use a sheetmetal (also called a shim gasket) headgasket to bump the C/R a bit further. This along with the .060 overbore might give a decent C/R. If they have been out of service for years (and you can get a spring compressor) get some lapping compound and a lap stick and lap the valves so they will seal. This is standard light-rebuild stuff.
None of this should involve as much money as time.
Old Oct 5, 2009 | 07:28 PM
wesrams1's Avatar
Car: 1992 Camaro RS
Transmission: stock
alright thanks man, this helps alot
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
