Aftermarket fuel systems
Old Oct 5, 2009 | 09:32 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I am going to be running an Aeromotive 1000 setup with a sump tank soon. What are you guys that have similar setups doing with mounting the fuel pump and filters? Are you welding brackets to the tank itself or drilling/tapping the frame?
I am sending a new gas tank and a sump tank to be welded up and am wondering if I should have brackets for the pump and filters welded on the side while i have the chance.
Anyone have pics?
Old Oct 6, 2009 | 08:41 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: Aftermarket fuel systems
fuel pump for engine in your sig?
sounds like way to much pump(not that its a bad thing) but for the money, i would go another route.
an a1000 is a 50/50 if you drive it on the street.
some have great luck, and some have issues with them overheating.
Old Oct 7, 2009 | 07:52 AM
Car: 1992 z28
I am running a 383 LT1 with a D1SC procharger at 12-15 lbs so hpoefully this will work out ok.
I know a few people running this system and have had no problems so yea I hope I get the same results.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
