Flywheel/Clutch cover GM#10241153 Where to buy!
Car: 88 Iroc TT
Engine: Gen 2 LT1 Carbed
Transmission: WC T5
Axle/Gears: 10 Bolt
Anyone know where I can find one of these for my 88 Iroc? MANY MANY searches with no luck
Discontinued gm part
From my research I believe the t56 cover will work with some minor mods just cant seem to get a definite part#???
ANY info greatly appreciated!!!
Thx
Thx
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Flywheel/Clutch cover GM#10241153 Where to buy!
If all else fails, setup an automatic search on ebay. One will show up and ebay will email you.
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
This thread is old, but I have a brand new one...
The T-56 cover is indeed the same, except that the bottom 2 holes are in a different place, and either the cover or the BH will need them drilled. In fact I used my T-5 cover on my T-56 by drilling its BH.
That would be an EXTREMELY eeeeezie part to make out of sheet steel or aluminum. Might arguably be the single eeeeeeeeeeeziest part on the whole car to retrofit.
dbrochard
Oct 3, 2015 12:43 PM
