Error Code 34 help
Old Oct 9, 2009 | 11:51 AM
WSX123's Avatar
Car: 1988 Trans Am GTA
Error Code 34 help
88 GTA 350 my car is giving me this error code, how can i fix it, and what does it mean. i am familiar with MAF sensor, but does it mean it need replaced.
Error Code: 34 Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
Old Oct 10, 2009 | 01:26 AM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
Re: Error Code 34 help
I bought my car from the original owner with all receipts from day 1. This code was on about 6 of them. The maf was replaced twice and ecu was replaced once. I still had the code for a while. I checked all the wires continuity test from ecu to sensor and checked the burnoff relay. then i backprobed the maf to see the readings at idle and if they increased. I beleive it was around a half volt at idle and increased with throttle. Everything was good from my view so I priced a new sensor anyway but never replaced it since it is around 300. Now I havent had the code in a couple years.
I had read online somewhere that the manufactures of the maf sensor had the wrong blueprints and did not agree with the ecu. who knows how tru this is.
I would like to hear if anyone else has chased this code before?
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
