110mph Gage Cluster To 145mph. Help, Confused ! ! !
Old Oct 10, 2009 | 02:06 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hello there everyone, first of all thanks for looking in on my post.
Today I bought a 145mph gage cluster of a 92 Z28for $60.00 in the best condition possible.
My question to you guys is, do I need to do any special modifiacations to the gage cluster so it will read properly? Cause im confused on the part that if I put in the 145mph cluster would it be accurate to the 110mph cluster? Or do I need to change any sensors or cable's? Cause I dont want to be doing like 30 in the 145mph cluster and in the 110mph cluster it would read like 50 or so?
Any suggestion would be appeciated.
Thanks. Tony.
Old Oct 10, 2009 | 06:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 110mph Gage Cluster To 145mph. Help, Confused ! ! !
In your circumstances, the swap is plug and play.
JamesC
Old Oct 10, 2009 | 08:10 AM
Engine: 3.0L 2JZGE
Hey JamesC,
So according to you its just a plug and play? Does the computer on the car adjustes its self or so?
I also read a lot of the post you have done for this topic, I just didnt find anything that I was looking for.
Also I was trying to take of the socket bulb from the back but how the hell do you take those off? I try twisting and pulling that ddnt work and this morning I was looking at it very close and I saw like a lil clip in between. So now does that hold it in place? Or do I need to get some needle nose pliars to pull out the clip?
Thanks. Tony.
Old Oct 10, 2009 | 09:24 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
It should be plug-and-play. I'd worry more about the 190,000 miles that could be on the odometer in the replacement cluster.
Of course, rolling one back is nearly impossible by design...
Old Oct 10, 2009 | 09:28 AM
Engine: 350 4BBL
... Does the computer on the car adjustes its self or so? ...
Both clusters receive the same signal in pulses per mile. They interpret this into miles per hour.
Old Oct 10, 2009 | 09:45 AM
JamesC's Avatar
I've never seen a socket that didn't twist out, though I haven't seen them all. The bulb in your case may be soldered to the socket.
JamesC
Old Oct 10, 2009 | 12:40 PM
Engine: 3.0L 2JZGE
Actually you are correct they do twist to left to take out. Where can I get these bulbs with the sockets at? And can I get brighter ones?
Thanks. Tony.
Old Oct 10, 2009 | 12:41 PM
Engine: 3.0L 2JZGE
In my case I dont have to worry about that, because the odometer reads 130,000 on the one I bought for $60 and the one in my car reads 150,000 so I'm in good shape on this one?
Tony.
1992Z28!
Nov 19, 2015 07:33 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
