Leak at MAF and a noise at the rear
Old Oct 10, 2009 | 11:36 PM
89_IROC-Z28's Avatar
Where the intake tube connects to the MAF is loose even with a clamp tightened around it. Is there a spacer or something that goes between them?
I circled where it is always loose.
At the rear of the car there is a hissing or vacuum leak sound. I have checked all of the fuel lines/hoses and the sending unit. I also checked the filler neck to make sure it wasn't leaking, and tried loosening the gas cap. Is the sound just the fuel pump running? This tank has the plastic baffles in the bottom of the tank and my old one didnt. Are the baffles causing me to hear the pump working?
Old Oct 11, 2009 | 02:12 PM
Re: Leak at MAF and a noise at the rear
I figured the question about the leak before the MAF sensor would be a quick answer...
Old Oct 12, 2009 | 06:26 PM
Well I guess I can make a spacer for the intake whether there is suppose to be one or not.....
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
