$400 for replacing intake gaskets on 350 TPI...fair price???
Old Oct 16, 2009 | 02:34 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Any feedback would help thanks
Old Oct 16, 2009 | 03:29 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: $400 for replacing intake gaskets on 350 TPI...fair price???
Is that total? (parts+labor)
Or just labor cost?
Old Oct 16, 2009 | 04:11 PM
maks10's Avatar
Car: 1990 Trans Am
total with tax $428.00...I was looking on how to do it myself and looks too much for a beginner. I hoping this is a good price since he was reffered by a friend.
Old Oct 16, 2009 | 04:18 PM
It took me about 3 hours to put the TPI back together on my car. The complete fel pro gasket kit is about $40 from autozone. So you are paying about 385 for labor. I was a mechanic in the air force, I have never paid to have anything worked on, except a transmission build, so I am not to savvy on labor costs. If I were to do if for someone else I'd charge around $200+parts to do it personally, so for having a shop do it that doesn't seem to out of line price wise to me.
Old Oct 16, 2009 | 04:53 PM
maks10's Avatar
Car: 1990 Trans Am
Thanks for the info! Really appreciate it.
Old Oct 16, 2009 | 05:07 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
yeah. you got do look at it this way..if his rate is 80 dollars an hour and he worked for 4 hours and bought a really expensive manifold kit then no. My friend paid a mechanic 200 bucks to replace my fpr, injectors, throttle body gasket, plenum gasket etc, excluding parts. in take gasket is probably better to have down by a pro if you're a beginner. but thats the beauty of learning. Give a man a fish, he'll eat for a day. give a man a fishing pole, he'll eat for a lifetime.
Old Oct 16, 2009 | 05:13 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
When they are putting it back together, have them drop in some replacement injectors from some place like FIC.
Old Oct 16, 2009 | 05:38 PM
Or get a set of SVO 24# they can be had for $75 off ebay.
Old Oct 16, 2009 | 09:30 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Been awhile since I looked up the labor for tpi intake gaskets, but I think its close to 8hrs to r&r upper and lower and clean the the egr passages.However, an expierenced mechanic should be able to do the job properly in about 3-4hrs.I think it took around 3hrs to do mine the 1st time I did one. So at $400 with a labor rate of $80/hr, the labor time is 5hrs which is very reasonble.
Old Oct 17, 2009 | 01:02 AM
poppa843's Avatar
The mechanic I take my car to told me it would cost 650 for the same job on mine. I'm putting it off till I work up the courage to do it myself or find a better deal.
Old Oct 17, 2009 | 09:29 AM
maks10's Avatar
Car: 1990 Trans Am
Are new injectors a need as well? Or is it a convenience factor since the intake is off? I never thought to replace them. Yea I was hoping to do this job myself but realized after looking at this site it maybe to advanced for me at the moment. Right now Im just finding out how these gaskets work/peice together with the motor. Learning everyday. Still love the car!
Thanks everyone for all the feedback, really appreciate it!
Old Oct 17, 2009 | 02:28 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The $400 would be better spent on tools and a shop manual. At least that's always been my philosophy. I've never had good luck paying others to work on my cars.
Old Oct 17, 2009 | 04:18 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Pulling the intake isn't that tough of a job. Yes a few special tool like torx bits are required, and a timing light would be needed to set your timing. You can buy all these for way less that what the shop wants and have the knowledge and satisfaction you did it yourself.
One thing a newbie does when pulling an intake off it they don't get the engine to where #1 cylinder is in the firing position. If you don't do this you will have to find #1 TDC on the compression stroke. So, a little pre planning makes the job much easier. It's easy to find TDC, pull the distributor cap and bump the engine over til the rotor is pointing to the #1 terminal on the cap BEFORE pulling the distributor out. This way when you put it all back together you just need to get the distributor and rotor back in the same position, and make sure the oil pump shaft is engaged with the distributor and the distributor is fully seated. We can explain further if you do decide to do this. Doing a little work before pulling the intake will allow you to easily fire the car up and use a timing light to set the timing. Again if you attempt this many of us here would be more than happy to help you with advise.
And as JV999 said, a shop manual is the first place for you to start. Take a good look at it, ask questions, then decide if you want to tackle this on your own.
1992 Trans Am
May 10, 2023 07:19 PM
okfoz
Mar 9, 2017 02:35 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
