New Cylinder Heads Question
Old Oct 16, 2009 | 05:43 PM
Harwood's Avatar
Car: 1985 Pontiac Firebird
Engine: '93 LT1
Axle/Gears: 4:11
I picked up some ProComp alluminium heads and I've got a few questions before I make a mess of things.
1)What kind of sealant should I be usingon the head bolts? If I stroll into my local Part Source, will they be able to kick me in the right direction?
2)Do alluminium heads get torqued to the same # as stock heads? Or do I go by the type of head bolts I purchase. (I'm picking new ones up tomorrow morning) I looked all over the ProComp website and couldn't find anything, so I thought, who better to ask than you guys.
Thanks again.
Old Oct 16, 2009 | 08:35 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: New Cylinder Heads Question
use some thread sealer or permatex on the threads and some oil or moly on the bottom of the head of the bolt. and torque the bolts to 70 ft lbs in increments, 20,55,70 ft lbs. Put some heat in the engine and check head torque again since aluminum expands more.
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
