Quick question on intake gasket
Old Oct 17, 2009 | 11:16 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Just wondering what most people recommend for installing intake gaskets. I know I should RTV the ends but not sure if I should do around the coolant ports on the gaskets or use none on the gaskets or just a light coat on the whole gasket? These are the gaskets I have http://www.summitracing.com/parts/FPP-1205/ (gasket material is printoseal) If you recommend using RTV should it be on both sides of the gasket? Just wondering what has worked best for people in the past. Thanks for the help!
Old Oct 17, 2009 | 11:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Quick question on intake gasket
I use a litte RTV on both sides of the coolant ports ( inc the rears ) just be sure; have never had a leak
Old Oct 18, 2009 | 04:51 PM
toomany's Avatar
I've done it with and without the RTV before. Never had an issue either way. If anything, the RTV helps hold the gasket in place when setting the intake down.
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
