Engine Oil / Transmission Cooler
Old Sep 21, 2009 | 09:42 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Hello Everyone,
After years of work my restoration is nearly complete. To protect my project, I am going to buy an engine oil cooler and transmission cooler. I also have a remote "spin type" filter for my transmission. Does anyone have a reccomendation of oil cooler / tranny cooler? If I install both a tranny cooler in addition to the radiator and the remote filter, will I have a problem with flow restriction?
Below is a link to the unit I am thinking of purchasing. Any thoughts would be appreciated!
http://www.summitracing.com/parts/DER-15903/
Old Oct 17, 2009 | 12:14 PM
fernando rs's Avatar
Car: 1988 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 4TH. GEN. REAR
Re: Engine Oil / Transmission Cooler
That tranny cooler looks really good to me. You shouldnt have any problems with flow restriction,as long as you replace your filters regularly.
Old Oct 17, 2009 | 12:44 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
i would get a by-pass kit it cools and cleans the oil better i have one and the oil is still good after 5 months and 11334 miles
as for the trans kit remember too cold is just as bad as too hot i have the trans to the aftermarket cooler then the stock one then back to the trans
http://www.fordfuelinjection.com/fil...rans_temps.gif
transmission and oil temp gauges are always good just so you know whats going on
Old Oct 17, 2009 | 06:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Why do you think you need a ext oil cooler?
If you do install get one with a inbuilt thermostat so oil warms up first before being passed to cooler otherwise oil temps will be too cold leading to increased engine wear
Old Oct 18, 2009 | 07:01 AM
wildjyoung's Avatar
After searching it seems most people either recommend or have an oil cooler from the factory. My car does not, so I figured an external one would be good. The one is the link I provided bypasses the cooler until oil temperature hits 180.
Old Oct 18, 2009 | 07:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Even so water boils at 212 ; you want to run 200 or better to boil off the water and contaminants from the oil otherwise you get sludge build up.Most users of oil coolers are beating on their engines hard like on road courses.
The Vette LT1's went to Mobil 1 and deleted the oil cooler previously fitted to the L98's which was only a option , not std fitment
Old Oct 18, 2009 | 08:27 AM
wildjyoung's Avatar
Basically you are telling me an oil cooler is a waste and even harmful. Unless I am beating my car badly. This car is going to be a weekend warrior with little strip time. I just want to do what's best for overall HP and durability.
I always run full synthetic in all of my cars.
Old Oct 18, 2009 | 04:52 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you are really worried you could run the Vette L98 oil cooler that fits between the block and oil filter ( if it fits F-Body chassis ).Has two coolant lines running to it
Typically lowers oil temps 15 -20 ( closer to coolant temp)
Often for sale on eBay or Corvette Forum
http://forums.corvetteforum.com/c4-p...and-lines.html
jhawkeye
May 25, 2022 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
