1st gen sbc heads
Old Oct 19, 2009 | 06:43 PM
pontiacsteve's Avatar
Car: 82 z28
Transmission: auto th350
Axle/Gears: stock
1st gen sbc heads
I am rebuilding a 1979 350 engine and am looking at roller tip rockers. The ad says it will fit all 23 deg heads(mine are stock "882's" .Are they 23 degrees? Also I read a performance book that suggested not to use full rockers with needle bearings for street use. I didn't see any that didn't use them. Any thoughts? And are they self aligning or not?Thanks
Old Oct 19, 2009 | 07:15 PM
rybread11's Avatar
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Re: 1st gen sbc heads
yes 23*, no not self aligning, don't know about the needle bearings, maybe the book is old and now all of them use needle bearings, when before they were considerd only raceing peices, but dont know on that one.
Old Oct 19, 2009 | 07:20 PM
Car: 82 z28
Axle/Gears: stock
thanks,would you happen to know if there is much HP gain of full rollers over roller tips?
Old Oct 19, 2009 | 09:58 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
maybe a couple hp.
Old Oct 19, 2009 | 10:12 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Make sure you have those heads magnafluxed. 882s are thin cast smog heads that are prone to cracking.
Old Oct 20, 2009 | 05:30 AM
Car: 82 z28
Axle/Gears: stock
thanks to all for info.
midge54
Dec 27, 2019 04:14 PM
CRFred
Feb 7, 2016 11:39 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
