valvetrain questions.
Old Oct 20, 2009 | 03:07 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I've heard that Hyd. roller lifters can be rebuilt, is this true? if so does anyone make a rebuild kit?
also, would I need self aligning rockers on iron LB9 heads?
Old Oct 20, 2009 | 10:21 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: hyd. roller lifter rebuild?
you don't need a kit, just first be sure your rockers don't have any scoring on the outsides. Then disassemble them, one at a time, clean everything, and reassemble. I made myself a little j-hook tool out of an ordinary paper clip, the other end should be made into a loop by wrapping it around a pencil and twisting, This makes it easier to hold. BTW, get rid of the pencil after making the loop. On the hook end, you'll need to use needlenose pliers to get it close to right. There is no perfect. I've done hundreds of these lifters this way, they work fine. Just install, adjust the rockers, run an oil pump primer while turning the crank, then continue with getting the engine started. This is entry level stuff that any newb can do with confidence.
Old Oct 30, 2009 | 09:44 PM
ericjon262's Avatar
so basically, you're saying the lifter rebuild is more of a thourogh cleaning?
also do I need self aligning rockers on the iron LB9 heads though?
Old Nov 1, 2009 | 10:14 PM
ericjon262's Avatar
Re: valvetrain questions.
anyone know?
Old Nov 2, 2009 | 08:22 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I believe 87 and later model LB9 heads require self aligning rockers. You will also need the narrow ones so that they fit with the center bolt valve covers. I know crane makes a set that is designed specifically for this application.
Old Nov 2, 2009 | 03:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You need to check what type is on your engine at present .Anything could have been changed in 20 years
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Zell1luk
Sep 29, 2015 10:36 AM
raymondandretti
Sep 27, 2015 06:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
