ESC module problem !
Old Oct 20, 2009 | 08:46 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
ok im getting code 42 wich in the haynes manual states :Electronic Spark Timing - Poor electrical connection, open or short in circuit, defective ESC module or " eletronic spark control module" , or defective ECM , well before this i was getting SES light with codes 15, 33,42 , well i replaced the map sensor and that got rid of code 33 , i also just relaced the coolant temp. sonsor for code 15 " and that went away and for code 42 i installed an igniton control module thinking it was the one the code was calling for but i was wrong , i needed a new ESC module not an ignition control module , so obviously i didnt fix the problem , i just spent 50 dollars on something that didnt need fixing , so now before spending another 50 dollars on a new ESC module , what else could be causing this code and does the circuit run along the two connectors that go to the ignition coil ? i really dont want to spend 50 dollars an an ESC module and then not have the problem fixed , btw im running rich , could this be caused by a weak spark ? , im @ TDC all is stock and i dont think idle speed would affect this , any help would greatly be appreciated
Old Oct 20, 2009 | 09:26 PM
water boy's Avatar
Car: 91 gta firebird
Engine: 350 tpi 60 over and super charged
Transmission: 700r4 2500 stall
Axle/Gears: moser axels eaton locker 3.73
Re: ESC module problem !
i have the same code in my 91 gta that wont go away but when i hooked it up to my snapon scanner and taked to a few freinds they seem to think that it is either my knock sensor or my box for the super charger but i am working narowing it down that is why i am hear trying to find out my timing issue first
Old Oct 20, 2009 | 09:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is the ESC wire connected together? It's on pass side, near strut tower - it's what you unplug when setting base timing.
Old Oct 20, 2009 | 09:35 PM
yes it is connected , im talking about the box on the drivers side right nest to the dizzy next to the brake booster , that ESC module , does the circuit run along the ignition coil ?
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
