Scraping Noise From Rear
Old Oct 21, 2009 | 09:31 AM
DomesticCheese's Avatar
Car: 1984 Chevy Camaro & 1988 Trans Am
Engine: H/C/I LS1 & 305 LB9
Transmission: T56 Magnum-F 2.66 & Stock T5
Axle/Gears: QP 9" TruTrac 3.70 & Stock 10bolt
I was just driving yesterday and was turning onto the highway - I did a 0-70 pull for fun. Broke it loose a bit - not much - I've done it hundreds of times.
Anyways - I hit 70 and let off and just put on cruise control.
I get back into town about 5 minutes laser and realize I'm hearing a scraping noise coming from my rear left wheel.
It gets louder as I accelerate - but doesn't stop when I brake.
When I first start driving - for the few couple minutes if I'm under around 10mph I won't hear anything - after a few minutes though I'll hear it at almost any speed.
I do have a popping noise already happening when I brake although I checked and my caliper is loose - and I just haven't bothered to take the wheel off yet to tighten it - could this also be causing it or perhaps I just need new pads?
Thanks!
Old Oct 21, 2009 | 02:09 PM
Re: Scraping Noise From Rear
Anyone? I'm a bit desperate to fix this as the car is currently for sale and the noise is loud and very obnoxious.
Old Oct 21, 2009 | 02:14 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
well you deffinatly need to tighten that caliper first. once you do that, and have the wheel off, im sure you can see something obvious and out of the ordinary. if you have rear disk, sounds like maby since the caliper is loose, the pad fell out or fell down and is riding on the rotor's hub flange. idk, just a suggestion. i saw an s10 do that.
Old Oct 21, 2009 | 02:42 PM
alrighty - thanks for the response!
I may do it tonight.
I'm sick atm so I'm kinda trying to force myself to go do it.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
chubsworth
Aug 26, 2015 02:34 AM
BlackBoulder
Aug 11, 2015 11:15 PM
