What does the thick hose under the air cleaner go to?
Old Oct 22, 2009 | 03:55 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
after doing a lot of reading i decided that until i get a cowl hood i'll go back to the stock air cleaner.
i was just looking at it and on the bottom of the one arm of it theres what looks like a metal hose. where does that go to?
Old Oct 22, 2009 | 04:09 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: What does the thick hose under the air cleaner go to?
Sounds like you're referring to the heat riser - it normally just goes down to a fitting on the exhaust manifold. It is supposed to take in hot air from around the exhaust manifold when the car is cold, to help it warm up faster. It won't hurt anything to remove the hose, although it needs to be there to pass smog visual check.
Old Oct 22, 2009 | 06:24 PM
Convoy25's Avatar
ah yes makes sense, thanks a lot
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
