Will 187 heads work in place of 081?
Old Oct 22, 2009 | 06:54 PM
stormmanners's Avatar
Because of the issue we had with our old heads we have to find new heads for a 89 firebird 305 TPI. The heads that were on it was casting #081, and the only heads that I can at a shop around my area is 187. Will casting #187 heads run on a 305 V8 TPI?
Old Oct 23, 2009 | 12:52 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Will 187 heads work in place of 081?
Yes they will work. They are both center bolt valve cover heads with 58cc chambers. The swirl port 187 heads were found on LO3 (305 TBI) cars. They flow less on the intake than 081's but flow more on the exhaust. They are fast burn heads so you will not need to run any initial timing advance (TPI cars had around 6 TBI had 0). The car may run funny on the stock tune since these heads will change the overall timing needs of the combo.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Street Lethal
Aug 12, 2015 11:33 AM
