67 heads on a 95 block??
Old Oct 25, 2009 | 04:19 PM
my84camaro's Avatar
will 67 chevy heads fit on a 95 350 block?just wondering cause I got a set of rebuilt 67 heads and a edelbrock intake (carb)and was wondering casue I dont want to have to buy another intake to match the 95 heads.
Old Oct 25, 2009 | 04:57 PM
my84camaro's Avatar
Re: 67 heads on a 95 block??
any one know?
Old Oct 25, 2009 | 05:14 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well kinda need more info. If the heads came of a 67 gen 1 SBC v8 and the 95 block is a gen 1 SBC not like an lt1 or something then it will work. However the 95 heads are probably 100 times better than the 67 heads even if there not the best of that year. Even though a new intake may be another few bucks i suspect it will be well worth it.
Old Oct 25, 2009 | 05:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The other issue is accessory holes - the 67 heads will not have any accessory bolt holes, thus no place to mount your alternator, etc. Unless you get old school accessory brackets that use block holes and header bolt attach points instead of head mounting points.
Old Oct 25, 2009 | 05:28 PM
my84camaro's Avatar
the 67 is a 283.and the 95 is a gen 1.the reason I'm asking is I have the heads,intake and carb already.the 67 heads are I think 58cc heads and I do want to boost up compression alittle so I was thinking it would be a good fit
Old Oct 25, 2009 | 05:31 PM
my84camaro's Avatar
the 283 came out the the monte I have,I put the 350 in it all ready,v-belt set up.everything on the 283 I was going to put on the 350.the only thing I dont have hooked up other then the intake is the alt.have to get a intake to do that
Old Oct 25, 2009 | 05:33 PM
my84camaro's Avatar
what would the compression be on the 95 block with the 58cc heads.the 95 block came from a truck and the stock 95 heads are 78cc heads.was told the stock 95 motor was 8.7.1 comp.
Old Oct 25, 2009 | 05:38 PM
my84camaro's Avatar
is'nt the only difference between the blocks are the rear main seals and the 87 and up blocks have the provisions for a roller cam?
Old Oct 25, 2009 | 07:16 PM
Pretty much there the same. I mean the 67 283 was probably has a small journal block and theres other small differences but there still essential the same motor. Compression ide guess would be around 10:1 off hand without doing the math to get a precise number. Although again although i think it will physically fit i think the head is probably a pretty bad choice for performance. Will it run? Sure. Will it run well? Doubt it. Heads are a huge deal and back in 67 knowledge on the subject was pretty primitive by today standards. Better yet if the 350s got vortec heads on it thoes are great flowing heads by stock standards and even some aftermarket heads! So all you would really need is a new intake you could reuse the carb if you chose the right manifold and have an even stouter combination. The compression is fairly low but to me any gains made by upping the compression would be lost by the poorer flowing heads.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
