need help with diagnosis
Old Oct 26, 2009 | 03:24 PM
RSisu85's Avatar
hey ive got a 91 RS v8 w/ auto trans. recently the engine speed seems to be way too high, even in overdrive (for example at 50mph its up around 4900rpm) the check engine light sometimes comes on, but only if im on the highway (i can drive around in the city all day w/o it going on). im really not sure if its the trans, rear end, or sensors or whatever else. any suggestions or similar experiences would help...(btw, its my daily driver and im pretty broke right now so i cant afford to do major fixes that i cant do myself.) thanks.
Old Oct 26, 2009 | 07:08 PM
dirtyd6669's Avatar
Car: 87 Trans Am
Re: need help with diagnosis
have u tried adjusting the tps
Old Oct 26, 2009 | 07:19 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
ooooh, man that sounds like a slipping tranny.
Old Oct 26, 2009 | 07:26 PM
Zwrench's Avatar
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
Does the engine sound like it's revving at 5000 rpm at 50 MPH or is that just what the tach reads? Have you read the codes?
If the engine is actually revving like that at 50, it won't be long until you need a transmission if it's slipping.
89GTAOz
May 16, 2020 09:31 AM
BumpaD82
Feb 26, 2016 02:57 PM
Magman
Sep 12, 2015 11:55 PM
whtltng89
Sep 8, 2015 07:06 PM
